1 - 6 of 6 Posts
YOU CAN PUT A POWER COMMANDER ON, BUT IF YOU ARE JUST USING STOCK PIPE AND NO AIR FILTERS YOUR WAISTING YOUR MONEY. THE POWER COMMANDER DOES NOT GIVE YOU MORE HORSEPOWER, IT IS MADE SO THAT YOU CAN FINE TUNE YOUR BIKE AFTER YOU GET THE AIR AND EXHAUST DONE, ONCE YOU GET IT DONE TAKE IT TO GET DYNO TUNED, DON'T LET THEM TELL YOU THAT WE JUST DOWNLOADED SOME MAPS TO SEE WHICH WORKS, BECAUSE NO 2 MAPS ARE THE SAME AS NO 2 BIKE ARE, PLUS DOWNLOADING A MAP FROM A GUY IN TEXAS AND YOUR IN THE EAST COAST THEY WON'T WORK, THE REASON FOR THIS IS SEA LEVEL ALTITUDE, THIS WON'T AFFECT CARS BECAUSE THEIR ECU WORKS DIFFERENT THEN THE BIKE ECU, CAR FINE TUNE THEMSELVES AFTER ALL THIS WORK, SO SAVE THE MONEY GET THE AIR AND THE EXHAUST THEN YOU YOUR POWER COMMANDER.
buy it when you can afford it. if your still stock use the stock upgrade map. it won't get you more power but it will smooth the bike out. after you get exhaust and air and can afford a custom map get 1. every 1 elses maps will get you in the ball park till you get your own. :bigthumbsup:
1 - 6 of 6 Posts
