1 - 3 of 3 Posts
Just got one of these today and was curious if you can mess with AFR with them I literally cant find anything on using the program aside from a little fuel map adjustment. I want to try to get my AFR in a good range considering I'm running Cobra Swepts without baffles and no fuel adjustment right now Thank you guys ahead of time
you will need something to measure the exhaust gases if your going to be playing with the AFR.
You can make things go horribly wrong if you haven't played around with them before.
The only device I have used myself is the Innovate LM1 (now replaced by the LM2)
http://www.innovatemotorsports.com/
Good luck! :bigthumbsup:
This would work with a motorcycle?
1 - 3 of 3 Posts
