1 - 14 of 14 Posts
I took off my risers last night and hand polished them it took me close to five hours to get them to the finish I wanted. Only thing is on the inside I didn't polish the indention on the inner of the risers but They turned out pretty good
Discussion Starter · #2 ·
Pic
Another pic. I can only post one at a time with the iPhone app
Nice job you did there
Those look great bro! I added 2" extensions to mine and polished them all together, and like the look.
Thank you guys.
Yeah it the next couple days I'm goin to do my wheels, rotors, bolts and brake cal also try to do the drive shaft and swing arm sometime
A tip for smoothing out cast aluminum ( swingarm), use a D/A sander. I polished one for Bordeaux, and it was taking for ever to smooth it out. I broke out the D/A Sander, went 80 grit, to180 grit, to 400 grit, then wet sanded out tthe remaining scratches. Total pain in the a55.
-Josh
nice job wish I had patience like that
What exactly do you mean by "hand polished"? Did you not use a buffing wheel at all?
Great work, bro (and fellow polisher LOL). I did mine and put some of the Kuryakyn accent trim on it. I also cut off the mounting tab and ground it down flush (sunk tach in cowl).
1 - 14 of 14 Posts
