1 - 5 of 5 Posts
Got A problem my 109 leak oil on the left side of the air box.It look like it's coming from or beside the hose that you drain the oil.I've change the oil an drain some of the oil out of it an I still got that problem.Can anybody help me solve this problem.Thanks
Discussion Starter · #2 ·
My 109 leaks oil on the left side beside the air box look like its coming down beside the hose that you drain the oil on that side I've tried changing the oil draining some oil out of it I still got that problem can anyone help me. Thanks
Too much oil
You can download the oil check recommendation from Suzuki at http://www.billydump.com/cav/m109_oil_level.pdf
How much oil did you put in it?
Tracy
Maybe its the "puking" problem others have mentioned. You said you drained some out but maybe its still just leaking out the intake. Unless it looks like its coming out the valve cover, I would suspect previous puking leftovers.
Even if you corrected the oil level, you still might see some some more oil as it is in the air box already.
1 - 5 of 5 Posts
