here you go read through this pay close attention to what square rounder has to say!!! good luck http://www.m109riders.com/forums/showthread.php?t=127194&highlight=oil+breatherI know that over filling can cause this but it didn't do it until just before the oil needed changed. Does anyone know why this happens when the oil is not over filled? HELP!!!!!!
Amsoil..........9160 milesWhat oil are you using and what millage are you at?
Thanks for the link, I sent square round a PM with a couple questions.here you go read through this pay close attention to what square rounder has to say!!! good luck http://www.m109riders.com/forums/showthread.php?t=127194&highlight=oil+breather
It seems a little early but some people have had success changing back to a non synthetic oil. Usually there millage was higher but you can give it a shot.Amsoil..........9160 miles
Yes Ryan, i've changed back to non-synthetic,,, and have not had a problem. It's strange,, i KNOW that i had the correct level with Synthetic, checked it bunch of times. AND,, when i went to change it the last time... 5000miles..... oil low and filter covered.It seems a little early but some people have had success changing back to a non synthetic oil. Usually there millage was higher but you can give it a shot.
Pegasus, the reason the catch can works is because the crankcase is no longer subjected to the vacuum in the intake. As you said, high vacuum sucks the oil up. With a catch can the only way the oil comes up is for crankcase pressure to push it up.And adding a catch can as some have done is not a fix. It just sends the oil somewhere where you don't see it and can lead to low oil levels.
Yep :agree: only a teaspoon of oil ever caught in my "oil catch can" in thousands of miles. Never even enough to drain. I NEVER overfill or had overfilled my oil when this was happening either.Pegasus, the reason the catch can works is because the crankcase is no longer subjected to the vacuum in the intake. As you said, high vacuum sucks the oil up. With a catch can the only way the oil comes up is for crankcase pressure to push it up.
Most that do this only get enough blowby mist into the catch can to create a few drops in it over hundreds of miles.
Doing it that way, I can see how it would work. Heck you don't even need the can for that, just a filter at the end of the hose. There's still 2 drawbacks though. 1, you're not getting the top end lubrication that routing the oil mist to the intake provides, 2, States that are going to emissions testing/inspections for motorcycles like CA. will at the very least require you to route the vent hose back to the airbox if not make you remove the catch can. And of course like with the exhaust systems, there will be fines for that.Yes, it is little to nothing that is comming out of the motorcycle, but it is still bad for the environment. Do you want to be part of the problem? Or part of the cure? But I agree that it's better than having oil all over the bike. But if some bikes do it and most don't, there has to be a cause for it that can be fixed without adding a catch can. That cause still needs to be identified and dealt with. It has to be something that allows more vacuum and or air flow in the crankcase forcing the oil out with it. Fix that and you've got a real cure. Mine doesn't do it so I can't find what isn't happening. Someone who's having the problem (or Suzuki ha ha) needs to find the real cause and fix it right. Technically Suzuki can be forced to fix it as it is a violation of the Clean Air Act at a corporate level to produce a vehicle that puts oil into the environment. If someone with the problem would bring it to the attention of the EPA, they would make sure that Suzuki fixed it.Pegasus, the reason the catch can works is because the crankcase is no longer subjected to the vacuum in the intake. As you said, high vacuum sucks the oil up. With a catch can the only way the oil comes up is for crankcase pressure to push it up.
You think that the oil going to the airbox is intentional to lubricate the top end? I beg to differ on that.1, you're not getting the top end lubrication that routing the oil mist to the intake provides"
I agree that some states that have emission testing may not look kindly on this fix. But I contest that keeping raw oil from spilling is much better than a little "dirty" air getting out.2, States that are going to emissions testing/inspections for motorcycles like CA. will at the very least require you to route the vent hose back to the airbox if not make you remove the catch can. And of course like with the exhaust systems, there will be fines for that.Yes, it is little to nothing that is comming out of the motorcycle, but it is still bad for the environment.
I kind of agree here except for being part of the problem. I truely believe that I'm helping the environment far more than hurting it by keeping oil from spilling. I say it's the lesser of two evils. I agree that Suzuki should step up and fix the problem, I also don't think that Suzuki will. I fixed the problem the best way that I could. Again I contest that catching the oil before it spills is a much better thing and far outweighs a little crank case air that's released.Do you want to be part of the problem? Or part of the cure? But I agree that it's better than having oil all over the bike. But if some bikes do it and most don't, there has to be a cause for it that can be fixed without adding a catch can. That cause still needs to be identified and dealt with. It has to be something that allows more vacuum and or air flow in the crankcase forcing the oil out with it. Fix that and you've got a real cure. Mine doesn't do it so I can't find what isn't happening. Someone who's having the problem (or Suzuki ha ha) needs to find the real cause and fix it right. Technically Suzuki can be forced to fix it as it is a violation of the Clean Air Act at a corporate level to produce a vehicle that puts oil into the environment. If someone with the problem would bring it to the attention of the EPA, they would make sure that Suzuki fixed it.
