1 - 2 of 2 Posts
Hey fellas, just the other day I noticed oil leaking from my left air box. It was coming out the air holes at the bottom. At the time It hadn't had an oil change since last summer. I took off the air boxes and cleaned all the oil up. I changed the oil (because it was time anyways) and I noticed it is still leaking a bit. I don't see it drip, but I can run my fingers along the bottom of the box where the breather holes are and oil shows up on my fingers. So what's up? Some gasket go bad? Some people have said that it might have too much oil, but like I said, it still has oil coming out even after I changed the oil myself. Any ideas?
Search "oil puke" you will be able to read for weeks. Unless you clean out the main airbox you will have residual oil in there and still will puke out. And this is also to assume it isn't over filled. Hope you bought K&N's to replace the stock airfilters. That way you can clean them out when the oil gets in there and keep going.
1 - 2 of 2 Posts
