1 - 6 of 6 Posts
Got new thunder mfg intakes in the look great had a few issues with them.Ordered them from DLP David is taking care of it they are very helpful and quik to resolve issues.Thanks DLP.:#1:
Kinda hard to tell from the picture, but it looks like you need to push the air filter back a little more. ???
Both Filters were crushed a bit and had small scratch on right but there! and a pretty major on the left.On both plates that mount to the air box.Also the right air box was not a perfect fit had to do some drilling on the holes (bigger) that mounts it to the motor(no biggie just of by a little).but Dlp says they are taking care of the other issue's.:clap2:
the bolts that go into the engine block make sure and use blue lock tight.... just my 2 cents worth... good luck!
I have a set and love em too.
Quick tip when you're ready to remove and reattach those filters for cleaning.
Boil a pot of water, dip the rubber ends in the water for about 30 seconds, then install them. They slip on like butter.
If you don't, you will have a tough go at it, and will likely bend or dent the filters in the process.
Also, the filters should be slipped pretty far back.
1 - 6 of 6 Posts
