Many know me here from being on the forum from the beginning. I have done quite a few write ups on assorted topics on the 109 over the years. I spend a lot of time on Facebook in the various 109 groups helping people. I have seen a TON of misinformation, between comments and YouTube videos. Many of the YouTube videos are decent, but lack all the information that will get you through the fix. You are getting someone who did some research and wants to build a channel so they film it. 90% of the time they are missing key information to help you, or their information is wrong. For that reason, I have started a YouTube channel dedicated to fixing the 109 from a trusted source.
We are just finishing up a second gear fix and I am starting on the wife’s bike in the next few days. She is burning oil and we think it is a valve seal. Since the bike has 82k miles on it, we decided to tear it down and do a full motor refresh as well. Crank and rod bearings, back cut transmission as well as rings and go through the valves. We won’t be getting into full detail in the videos of how to do stuff as that would take forever. I have 10 other second gear jobs waiting so we want to turn this around I a quick fashion so we will be doing videos every day or two through the progress. We have a ton to do as we are also pulling the whole bike down to frame and clean, check things and fix anything that needs to be done. You can check it out here.
Front motor mounts
Fuel filter replacement
Main air box removal and installation
How to check m109 FI light code
Arnott air ride manifold cleaning (Maintenance)
Secondary Installation
How to remove and install all body panels
How to install integrated taillight (Chinese version with wrong wires)
How to remove and replace a site glass for the master cylinder
Oil Change
There are others coming as well.
We have already done a full clutch video as well as replacing your oil pan or dropping it to check the sump screens if your clutch is bad..
If you see something that you want us to do, post up and we can see if it is in the cards.
Front motor mounts
Oil Change
