Guest
·If we could adapt this to a set of RC wheels would anyone be interested? A little pricey plus the adapter cost.
http://www.360brake.com/bhl.htm
Other than the intakes my bike is done.WOW! That is so very cool. :bigthumbsup: Are you going to do both fronts and rears? And were you planning to do your bike so we can see what it looks like on the 9?
I would definitely be interested, but suspect that I wouldn't be able to afford itProbably one of the coolest ideas I've seen in a long time.
I was thinking that the stopping power would be very limited also. Just by the size of it alone. It does look very slick. :bigthumbsup:Read a write up about the 360 brake looks good but no stopping power.
Even if there was more or the same square inch of pad used. In such a small area and concealed up, with some small vents. I would think under had driving/twistie roads that they would heat up a ton faster and take a lot more time to cool down. Boiling brake fluid is not a good thing to have.they have a 360* brake pad serface so actualy there is better stoping power with them and they look ausome. One other thing you can actualy see your wheels we work so hard to polish or have cromed!! I like um!!
:agree: Even though they are neat, one of the critical parts of brake design is the leverage they can apply to the wheel. That's why larger diameter disc brakes are more affective than smaller diameter, even if you add more pots to the caliper. And why the rim mount brakes on Buells are so effective. Moving all that leverage closer to the center of the wheel when most of the rotating mass is on the outside can't be very effective.Even if there was more or the same square inch of pad used. In such a small area and concealed up, with some small vents. I would think under had driving/twistie roads that they would heat up a ton faster and take a lot more time to cool down. Boiling brake fluid is not a good thing to have.
:agree: I wouldn't trade my world-class GSX-R1000 brakes for anything other than Brembos or Galfers. If the 360Brake is ever proven in the racing world, I might reconsider.NO :doh:
:agree: no thanks, I like to see that everything is in good shape.One word.................
NO :doh:
