If any one has the maintenance manual look in the wiring manual for a gear position switch or neutral switch. Find out what wires are going to the ECU , I believe there is a discrete ( ground ) that comes from the switch that lets the ECU know when it is in 5th gear. Suzuki has done this on the Gsxr motorcycles in the past. They also tend to have a discrete to retard ignition timing in the first couple of gears to make power smooth in the lower gears or keep it from wheeling on the GSXR motor cycles.
J R said:
You beat me to this 8) I was just fixing to post the same thing.I need someone to post where or what color wires, the gps ( gear position sensor ) are. All we need to do is find the different values for each gear and then get a 5 cent resister and whamo no speedlimiter and possably advanced timing in the first few gears :D Very common Mod on sportbikes. There know as TRE,S But really all they are is a 5 cent resister but they sell them like they make the bike more ridable and smoother faster e.c.t and derestrict the bikes top end all of which are true but it ain't all that tuff to do :bigthumbsup: It gets old having that thing cut on and off in 5th gear all the time :verymad:
Exactly, I had the TRE on my GSXR 1000. If no one steps up with the mantenance manual I am gonna see if the dealer ship will let me have a look in there manual.
I hope you guys get it figured out :evil:
2006 Boulevard M109R - ELECTRICAL
** Qty Required NotesÂ
1 31800-38G00
RELAY ASSY, STARTING MOTOR
2 31861-38G00
.COVER
3 09481-30501
.FUSE (30A)
4 09128-06013
BOLT, STARTING MOTOR (6X8)
5 32800-10G00
RECTIFIER ASSY
6 32830-48G00
BRACKET, RECT FTG
7 02162-0612A
BOLT, RECT FTG BRKT
8 02162-0625A
BOLT, RECTIFIER
9 33410-35F10
COIL ASSY, IGNITION
10 33410-38A20
COIL ASSY, IGNITION FRONT
11 33410-48G00
COIL ASSY, IGNITION REAR
12 33414-48G00
BRACKET, IGNITION COIL
13 09180-06195
SPACER, IGNITION COIL
4 6.4X10X18Â
14 09403-07308
CLAMP, HIGH TENSION CORD
15 01547-0535A
BOLT, IGNITION COIL
16 01550-0616A
BOLT, IGNITION COIL BRKT
17 33510-20E00
CAP ASSY, SPARK PLUG
18 33541-47D00
SEAL, SPARK PLUG
19 33542-38B00
SEAL, HIGH TENSION CORD
20 32920-48G10
CONTROL, UNIT, FI
21 32980-48G00
HOLDER, FI CONTROL UNIT
[b]22 33960-06G10
SENSOR ASSY, FUEL CUT [/b]Â 1Â
23 33970-48G00
ACTUATOR ASSY, EXHAUST CONTROL
24 33973-48G00
COVER, ACTUATOR
25 01560-0625A
BOLT, ACTUATOR
1 31800-38G00
2 31861-38G00
.COVER
3 09481-30501
.FUSE (30A)
4 09128-06013
5 32800-10G00
RECTIFIER ASSY
6 32830-48G00
BRACKET, RECT FTG
7 02162-0612A
BOLT, RECT FTG BRKT
8 02162-0625A
BOLT, RECTIFIER
9 33410-35F10
COIL ASSY, IGNITION
10 33410-38A20
11 33410-48G00
12 33414-48G00
13 09180-06195
4 6.4X10X18Â
14 09403-07308
15 01547-0535A
BOLT, IGNITION COIL
16 01550-0616A
17 33510-20E00
18 33541-47D00
SEAL, SPARK PLUG
19 33542-38B00
20 32920-48G10
CONTROL, UNIT, FI
21 32980-48G00
[b]22 33960-06G10
23 33970-48G00
24 33973-48G00
COVER, ACTUATOR
25 01560-0625A
BOLT, ACTUATOR
Thanks for the info but I need the actual wiring schematics usually in the back of the book.
ALL WE NEED TO KNOW IS WHAT COLOR OF WIRES AND WHAT PIN #S THEY GO TO ON THE ECU FROM THE GEAR POSITION SENSOR.
Alright - since this is something I'd like to see as well, you compelled me take the seal off my service manual... ;)
The gear position swith has 3 wires. On the harness side of the connector (they are different colors on the GPS side) there is:
  • Blue - which routes to side-stand relay and ECM
  • Pink - which connects direct to ECM
  • Black - which branches into 4 Black-white connections going into ECM. Doesn't give pin-outs for the ECM connections, though...
J
* Edit*
A quick cross-refence (as I learn to use the manual ::) ) shows the Pink is the only direct ECM connection and it is on pin 23. The Black ties to chassis ground, as do the Black-white wiring on pins 34, 66, 67 that the simple line wire diagram showed as branching... Hope that makes sense.
THANKS A BUNCH I will figure out the resistance values and have a answer within the next day.
* Edit*
Let us know what you figure out. This would be a good how-to post on the new "child of tech board" Lamont added once
we you get it wired down.
Jer
Lamonster - if you can scan it, there is also a page under the FI section with a more detailed break-out of the valve control. I don't remember the page number, but it is under the trouble-shooting section for the valve and shows pin connections for ECM, etc.
J
