Hey all, As some of you know I have undertook a huge off season mod project. Part of that was install of Kury LED FRONT signal light. I bought the duel filament lights so that I could maintain the running light. Well, install went well and lights worked perfectly, UNTIL I started the bike up. When the motor is running the Running lights go off and blink on and off. Directionals work fine.
Lights are wired correctly and load EQ is on directionals. Directionals flash properly as well. Called Kury and they were 0 help. He told me to switch the wires which I did even though I knew he was wrong. That made the problem worse.
Wired it back correctly per directions here and still work perfectly with the key in on position but start her up and running lights go out and start to flash. Bought a resistor to introduce into the running lights wire. Have not tried it yet but was wondering if anyone here has any ideas. Search and read every topic on it and found nothing. Anyone got something I can try?
