You can find the right tires in the sizes that you need if you go to DLP (site sponsor) or I found really good deals on jake wilson dot com then DLP will do a price match and beat it by $5. If you are running a 10 inch rim a 280 will work, but if you are still running the stock 8.5 rear then you would be pushing your luck and it isn't advised by very many people on here (and there is a ton of knowlegde from the members here.) 260 would be a good fit with a stock rim if you want to run metzelers.
