1 - 7 of 7 Posts
What type of setup do you have your bike at? IE Backrest, shaved beaver, bags etc?
lastly what size flag(s) do you plan on running? Full time or just for parades/funerals etc?
I saw a set up on a c90 that i think would work the same for the m109r.... where the 2 bolts are for the back rest mounting hardware to attach... the rear most bolt was replaced with a bolt that had the metal loop welded/fabricated to it... once in place you could slide a big flag pole into it with a set screw to hold it in place... wasn't exactly pretty but he only used it for parades and such. I would imagine if you have access to a welder you could make this for a couple bucks or less.
PM {afdad}! He's got your answer, cause he does it:nojoke:
1 - 7 of 7 Posts
