1 - 5 of 5 Posts
When my Stebel Nautilus air horn quit working, I found the air intake tube full of water. I assume the inside was soaked as well. Does anyone know a trick to get it working again or has had one apart?
Thanks!
give it a good spray of WD40 , let it soak well , then let it dry out well give it a good shake , and blow out with air , should do the trick ..........give it a try ..........
Did you have the tube zip tied under the seat? If so, how did water get all the way up there?
I didn't have a tube on mine, just the compressor with the horn attached to it. Unless it's mounted upside down I don't know how water would get in it.
I am pretty sure that he has my right side cover harness and it comes with one to protect the horn from doing that.
1 - 5 of 5 Posts
