Had it done at Dayton bikeweek. By smokin Gunz. They travel to all the big events. I watched them install. 10 orange LED's installed to frame with two way tape and liquid adhesive. One rubberized push button switch installed the same way right underneath the plastic molding behind the right side of gas tank. Suggestion: if you have it done or do it yourself put the switch on the left side this way at dusk if your riding you don't have to take your hand off the throttle while cruzin
I'll be switching mine over soon. Small transformer and 10 amp fuse hooked up next to battry. Years ago I use to install everything on my rides. I've gotten lazy over the years
. I choose orange because all the shows I go to red,purple,and blue seem to be the fad here in Florida and in Tampa they give you a hard time if your riding with emergency colors and purple is so close to blue it's just not worth it and I'm not to big on purple anyway. With orange I can cruise all night long with no problems and it helps our senior citizens see a little better. I also watched them install hyper white on a silver V rod that looked good as well. 8)
