Looks awesome althought i dont really care much for the windscreen. How much if you dont mind me asking ? did you take the wheels off yourself or did a shop do it for you ?
I pull them off myself and it ran me $500 for the wheels and $50 for the hub. If you do yours, here's a tip, the final drive hub and driveshaft comes off easy but re-stabbing the driveshaft was hard to do , you may get lucky, I sure didn't have any luck getting it done. The easiest and fastest way was to pull off the Secondary drive gear first, which is direcrtly linked to the universal yoke joint in front of the swingarm. You simply remove the plastic cover next to the crankcase(three screws), remove the small hex holding the oil plug with wires on it, then the four bolts holding the gear box. The uni joint will be right on that. Re-mount your Final drive and drivre shaft and take the uni joint from the Sec Drive Gear and slide it onto the end of the drive shaft at this end of the swingarm and now put the Secondary gear back onto the uni joint and slide the box back into place, re-bolt the box and re-add the oil, about two ounces, cause when you remove the gear the oil will come out but not much. Its the same oil you'll use when you remove and dis-assemble the Final drive Propeller gear for chroming. Oh yeah on the Final drive Propeller gear there are two screw holes that you use to pry the gear from the hub after you remove all the screws. you find the screw that fit into the holes and simply screw them in at the same time and it will lift itself right out. But Overall it was easy to do.
Thanks! for ALL the comments the AGREES and the DISAGREES everybody has there own, that's what makes LIFE so GREAAT! I had Polished Rims before and after a while, about a year the shine start to dull and the elbow grease it took for me was to much so I vowed to chrome everything after that. For Me it's much easier, just soap and water and some paper towels. Good Luck and RIDE SAFE!
look great i want to do my wheels but the chromer is telling me 4-6 wks. needless to say it's riding season i don't want my bike down for that long..how long did it take to get done and in what state did you get it done at
it took one week and I'm in Texas. There are two places I go to within 10 miles from me. I used to have to send my wheels to Cali, then I did a Google search for chroming in my area and found them, you might have the same luck, give that a try!
I have the silver one too. Your wheels really look choice. That with the chroming may be a nice winter investment In Germany we can only ride about 6-7 months out of the year if we are lucky so the last thing I want right now is that the bike 1 day is in the shop if it isn´t a must
The chrome wheels make it a different bike altogether. First thing I told my buds I was going to do was chrome mine out as well. That was before seeing yours. Now that I have, not chroming them isn't even an option. I expect it will make even a more dramatic difference on mine......(being black)
Hey bro all you need is a sissybar w/pad,boy does my wife love the looks of your bike with the shield,and she seems to think the bitch pad is thicker than the stock one she sat on yesterday,but the one on your bike looks stock to me,is it?
what is the name of the chromer in texas you used?
Related Threads
M109 Rider Forums
1.6M posts
32.7K members
Since 2006
