1 - 20 of 122 Posts
Motorcycle Oil Technical Facts
NEW! - 10W40 Amsoil Motorcycle Oil Test FACTS - Results Here
NEW! - 20W50 Amsoil Motorcycle Oil Test FACTS - Results Here
Motorcycle crankcase oils are specially formulated for motorcycle applications that have wet clutches. Most automotive oils are not suitable for use in motorcycle engines. A premium quality motorcycle specific oil typically has higher levels of anti-wear chemistry such as zinc and phosphorus than some automotive oils do, which are critical in protecting high RPM and high load and engines from wear and especially cam lifters and follower wear. That is not to say that all motorcycle oils have increased levels of zinc and phosphorus; many do not.
Over the years, automotive manufacturers have requested oil manufacturers to reduce zinc, phosphorus (an essential element in ZDDP, Zinc Diethyl Dithiophosphate) and other extreme pressure additives from the oil. The primary reason is that automotive manufacturers have requested is that they are extending emissions systems warranties to periods of 10 years/150,000 miles and they claim that high concentrations of these chemical additives were contaminating their catalytic converters and negatively affecting emission levels required to meet their 10 yea/150,000 mile warranty requirements. There are also a few motorcycles on the market that have catalytic converters, however they are not subject to the same 10-year requirements as the automotive industry for emissions levels.
We recommend looking at the oil manufacturers specification sheet and performing a comparison. If they won't provide the data a very simple spectrographic analysis lab test can be performed that will provide the exact PPM (parts per million) concentration of zinc, phosphorus and other chemicals. That is the only way to get accurate information. There is no reason why a reputable oil manufacturers customer technical service department should not have that data readily available for the consumer and if they do not you should be highly suspect as to why not and go out and get the data yourself before started using their oil.
Another issue with using an automotive type oil in a motorcycle with a wet clutch is that many automotive oils have friction modifiers. Friction modifiers in automotive oils tend to provide increased frictional reduction and offset a portion of the fuel economy lost when the U.S. Government mandated a reformulated gasoline for emissions requirements. However these friction modifiers can be detrimental to proper wet clutch operation and can cause slippage and other potential performance issues such as "engine start failures, a rough running feel and increased fuel consumption due to higher engine stall speeds".
It is also important to note that there are automotive type oils that do not contain friction modifiers. You have no way of knowing unless the specific manufacturer tells you. That is why we say it is better to be safe and use a motorcycle specific oil in a motorcycle engine with a wet clutch that meets the proper motorcycle specification as stated in the next few paragraphs.
A premium quality motorcycle engine oil can be stated to meet the requirements of API Service Classification SJ, SH, SG, SF, CH-4, CG-4, CF-2, CF and CD. Note that SH, SF, SG and CD are now obsolete. Motorcycles specifying an oil meeting any of the obsolete applications can use an oil with the newer classification oil because it includes, and supersedes, the requirements of the obsolete service classification. For example, if you have an old motorcycle that specifies SE service classification you do not have to go out and look for an oil with that service classification (and if you did you would most likely not be able to find any in stores as SE was outdated in 1979). The newer classifications include the outdated ones and are perfectly suitable for use. There are some motorcycle oil manufacturers that will include an older service classification on the bottle to so that consumers can specifically see that the oil not only meets all the older specifications but the newer ones as well.
It is important to note that as an oil classification is superseded by a newer one, that the newer one provides improved benefits over the older one in such areas as high and low temperature deposits, wear, rust and corrosion for example and is perfectly suitable for use. All quality motorcycle specific oils should also carry the JASO Motorcycle Specifications, which are either the JASO-MA specification (no friction modifiers) or the JASO-MB specification (with friction modifiers). The JASO-MA rating specifies that no friction modifiers are used. Note that the JASO-MB motorcycle does have friction modifiers, but is designed for motorcycles thatspecify theJASO-MB specification.If the oil does not carry one of these specifications, even if the other specifications listed above are present, We recommend finding an oil that has the proper JASO specification clearly labeled on the bottle.
Question. How should I clean my motorcycle engine? Will using AMSOIL Engine Flush in motorcycle engines damage the wet clutch?
Answer. AMSOIL Engine Flush may soften clutch materials to the point where clutch packages could be damaged, and is not recommended for this application. Using Amsoil Synthetic Motorcycle oil will clean your engine just by using it.​
Petroleum or Synthetic?
On the subject of whether or not to use a petroleum or synthetic motorcycle oil my recommendation is to use a premium quality synthetic. There is absolutely no comparison between the two. Synthetic oil has been proven to resist high temperature breakdown and shearing effects at higher engine operating temperatures for a much longer time period than petroleum oil and as a result allows the oil to stay in the specified viscosity grade much longer. Synthetic oil is more uniform in molecular structure and will reduce internal friction and thus provide for lower engine operating temperatures as well as provide for smoother shifting.
We have measured the cylinder and cylinder head operating temperatures in two identical motorcycles; one running petroleum oil and the other a premium quality synthetic. We measured an average of 15-20 degree F. temperature difference after a very mild ride and short period of idling. At extreme engine operating temperatures and conditions this value can be up to 35-45 degrees F. lower with synthetic oil. We have received reports of this from motorcyclists that have oil temperature gages installed in their crankcase. We received another report of a customer that when he was using petroleum oil in hot summer heat and traffic jams he would have to shut off his air-cooled V-twin engine because it began overheating. After changing to a premium quality synthetic motorcycle oil his engine temperatures dropped significantly and he no longer had that problem on hot summer days in traffic. Again there is no comparison between the two and anybody that tells you otherwise has obviously not reviewed documented test data and facts clearly showing that synthetic oil outperforms petroleum oil in every category.
We have a report of a dynamometer test run comparing a specific manufacturers branded motorcycle oil to a premium quality synthetic oil. In the first part of the test with the petroleum oil installed in the engine, transmission and primary chaincase the maximum horsepower (Hp) was 68.1 and the maximum torque was 80 lb.-ft. In the second part of the test the same motorcycle was used and all petroleum oil products drained from the engine, transmission and primary chaincase. With the synthetic the maximum Hp was 69.8 and the maximum torque was 81.3 lb.-ft. That's a gain of 1.7 Hp and 1.3 lb.-ft. torque, which is what We consider a significant amount of gain just from changing from petroleum oil to a premium quality synthetic oil.
Synthetic oil will hold contaminants in suspension longer and reduce any oxidation and provide for a much higher load capacity as well as provide for increased wear protection to critical engine parts such as pistons, cylinders, gears, camshafts and bearings. Synthetic oil also has superior cold weather performance characteristics and will flow at temperatures that will cause petroleum oil to solidify and can be used for extended drain intervals beyond that of a petroleum oil. Note that during extended drain interval operation you need to change the oil filter at the filter manufacturers recommended change intervals, then install a new filter, top off the oil and your ready to go. There are premium quality extended change intervals oil filters on the market that can be used for twice as long as a standard filter.
Discussion Starter · #2 · (Edited)
Synthetics and Slipperiness in Relation to Roller Rockers and Wet Clutches
As a side note, we have received many reports of motorcycle shops telling customers that synthetic oil is so slippery that is causes roller bearings not to roll and will result in flat spots on the roller bearings. This is absolutely not true. Synthetic oil is no more "slippery" than petroleum oil. Synthetic oil is more uniform in molecular structure than a petroleum oil but it is not more slippery and will certainly not cause roller bearings to roll. Roller bearings will roll whether they are using petroleum oil or synthetic oil and the only way the roller bearing on the rocker arm will ever stop rolling is if the needle bearings that support the roller bearing failed. Every automotive racing engine (as well as many other types of high performance engines) and most of today's high performance automobile engines use camshafts with sophisticated roller rockers with absolutely no problems of this nature whatsoever.
We have also received reports of motorcycle shops telling customers that synthetics are so "slippery" as compared to petroleum oils (which simply do not reduce friction as well) that wet clutch packs in their motorcycle transmission and even their automatic transmission of their cars and trucks will slip when using "slippery synthetics" even if there are no friction modifiers present. This is absolutely not true.
Look at it this way. Wet sandpaper removes paint as well as dry sandpaper does. The slipperiness of the water does not impede the sandpaper's ability to function. The same applies to the slipperiness of synthetic lubes in wet clutches. It is simply not an issue.However, just as rinsing the sandpaper keeps it cleaner longer so it functions better longer, so the synthetic lubricant keeps wet clutch plates cleaner longer so they function better. And, since synthetics are superior cooling agents to conventional petroleum lubes, using synthetics will help wet clutches last longer, too.
Petroleum oils have low resistance to heat and allow varnish and glaze to form on clutch plates, which can lead to slippage and increased heat generation and potential failure of the clutch pack. Synthetic oil is going to allow your wet clutches to perform better (especially under extreme heat, RPM and load conditions) and last longer than they would with petroleum oil subjected to the same operational conditions.
As a side note in respect to Automatic Transmission Fluid: synthetic ATF is not more "slippery" than petroleum ATF. The base fluids, whether or not petroleum oil or synthetic oil, play no direct role in the relative friction levels of wet clutches. The friction-modifying additives developed for petroleum oils work just as expected in synthetic PAO's fluids. The longer the fluid resists oxidation, the longer the original frictional properties remain. The superior oxidative stability demonstrated for synthetic ATF's thereby leads to extended retention of frictional properties.
can you go longer between oil changes with synthetic i have heard yes and no any insight on that :dontknow:
ocrusher, quite simply, yes, you can extend the use of most synthetic lubricants well beyond that of standard petroleum lubricants. However, many consumers as well as many independent companies are still skeptical of the life expectancy of synthetic oils and therefore would prefer to change even their longer-lasting synthetic lubricants at the standard petroleum lubricants' change intervals. Ultimately the choice is yours but be aware that no harm will come to your engine for simply extending the use of a quality synthetic lubricant beyond that of a standard petroleum lubricant.​
I know my test methods are nowhere near as scientific as what they use, but I don't see how they can say synthetics aren't more "slippery" than regular dino oils. That's where the extra HP gets picked up, from less friction.
Back when my daughter was in high school I helped design a project for her for a science class. All it was, was a polished steel plate about 36" long mounted at an angle. Her illustration was to show the difference between synthetics and regular oils. To do so, she would coat the plate with each oil, then place a flat steel block on the plate and time how long it took the block to slide to the bottom. Between tests both the angle and block were cleaned with degreaser, followed by soap and water, and allowed to dry. To show the difference each test was repeated twice. In each case the synthetic oil allowed the block to slide to the bottom by a substantial margin.
We built the test device at home and played around with the angle to use to get a controlled slide, neither too slow nor too fast, so we had plenty of opportunities to see the difference here too. The synthetic was Mobil 1 and the regular oil, I think, was Pennzoil. Both of the same weight, and both kept at room temperature. The only variable we couldn't show was if there was a difference with both oils at engine temperature.
This was 17 years ago, so I don't remember the exact differences, but it was very noticeable. :D
Great post
Great post
I have and will always recommend that everyone do a minimum of 3 oil analysis to begin with on there oil to see what is going on with there engine
Then do one every 4th. Oil change… if you pay attention to your oil analysis, you can get good information that might just save your engine and lots of money in the long-run
My oil analysis report that the Suzuki brand oil is working very well on my engine and I decided to stick with it so far… I am willing to try other oil if they meet or exceed the results that I am getting now
This post was not intended to promote any oil brand; its intents are to be informative.
Most folks does not know much about oil properties and there application
I hope to educate folks and influence them on making and educated decision on choosing the correct oil for their individual application
Not all oil are created equal, our bikes need a specific type of oil as we are sharing the engine oil with the transmission that has a wet clutch system
A lot of the clutch problem we are having I think is due to using the improper oil in the 9
As I have stated in other post here, I don't have any noticeable clutch issue at this time, (14,000 miles) and I think it is from using the right oil in this case… the Suzuki brand has been working well for me but not to say there is no better brand for this bike; they must have better out there; I just need to find it and put it to the test.
Its great that Amsoil put this info out there on how good their products are :D.
The oil debate is massive, which is better, cheaper, suited etc for each application. I have found Amsoil to be rather ordinary in both my car and bikes so now take all these "results" with the potential to be clever marketing. I used the 20W 50 motorcycle oil in my Triumph Speed Triple and within 1200klms I had changed it for something else because the gearbox felt incredibly notchy and was audibly louder (found that BP Superbike suited this bike really well after trying 6 different oils within 4000klms). I used the 10W 30 car oil in my turbo Subaru and when I removed that after 5000klms it was like sewing machine oil, quite black, smelt burnt and certainly didn't give me confidence in its abilty to lubricate.
I think sound and feel are the most important thing when deciding on a motorcycle oil. Which one do you think shifts best and which sounds best for your biased ear. If the bike is broken in, try a few different synthetics and the one you like best is the best one available for your bike.
Interestingly, one if the guys on a speed triple forum I am a member sent two samples of oil to Blackstone labs for analysis. One was Mobil synthetic motorcycle specific oil and the other was the eqivalent synthetic car oil of the same weight. The differences between the two were incredibly small showing that you could indeed use the much cheaper car specific oil and receive the same protection as the expensive bike oil. I'll see if I can find the reports and post them for interest sake.
Not trying to start oil debate no 9878997, just killing time waiting for my wife to get ready so I can go on holiday!!:D
Rob
same old bah bah bah, I ran dino and synthetic and the temps didn't drop degree, in fact my old blackbird ran about 5 degrees hotter on avg with synthetic.
Rob
yep great commercial and you can use "auto" oil in a motorcycle, there's no real difference other than price
Has anyone else tried rotella?
folks, for the first time I am running 10W40 Amsoil Motorcycle Oil full synthetic, after careful research
I currently have 14,000 mile on my bike
put 70 miles on that oil, so far it has been working very-well
more report to come as the miles is added up
As some may already know, I have only been running the Suzuki brand and did not have any luck with any other brand
i've got about 200 miles on mine so far, and my bike is silky smooth. definitely worth 22mpg.
I do not believe Rotella Oil to be best suited for motorcycles. I will only use Rotella in my diesel vehicles.​
1 - 20 of 122 Posts
