1 - 5 of 5 Posts
Here it is guys I went for a short ride today and all was well, till on the way home. My bike was running smooth then all the sudden it started missing when I went past 1/4 throttle at half throttle and beyond it misses and stalls let off the gas and picks back up. It pops and cracks? Idle or 1/4 throttle runs fine. Any thoughts? Stock bike 12,000miles. Plugs? Fuel filter? I'm fixin to start looking.
start with the fuel filter. also, if you've done any work to the bike under the tank check connections. sometimes things can get pulled loose.
Yep... Fuel Filter. It could be something else but the smart money is on the Fuel Filter.
I don't want to jack your thread but I just got back also from about a 60mi ride with the wife (she does not ride with me very often) and I had the same problem. I have 17k on a 07 with pc111 and cobra drags/kn's filter though. I see my back pipe is big time black inside. (running rich) on rear cilinder and missing like crazy. To hot outside right now but will first check the connectors I have heard so much about that come from the pc111 to the injectores. The shop installed it 2ys ago so I'm thinking that might be my problem. :dontknow: Hope we both get them running like they should be.
Yep sure enough it was the pre-filter:cus:
I was supposed to ride the skyway and the dragon tomorrow with jd and his dad on there way home from the meet.Of all times:edit:!!!! I went ahead and pulled the plugs while I was in there and going to change them as well. Wonder how long it'll take to get that strainer????
1 - 5 of 5 Posts
