1 - 9 of 9 Posts
Hey fellas.
So many people raving about the Metzeler tires here so I decided I will get them. Checking out Direct Line's site, I noticed the matching set for the 109 are not the same speed rating.
How is it wise or safe to use different-rated tires at the same time?
Why aren't the 130's for the front VR rated? Both tires are going the same speed!
Thanks!
I cant answer why they are not the same... Maybe they dont make them that way?
But I dont think it matters if you dont exceed the lowest limit...
I think a real issue would be radial VS bias ply tires.
Sledzep
Sledzep
You're absolutely correct :bigthumbsup: :bigthumbsup: :bigthumbsup:
That sounds right : bigthumbsup: but really, you only need to do that above 130 mph. :p :bigthumbsup:
Speed rating H or V, The tires have different rubber types and the V rated tire has a stronger sidewall to handel the
heat better. In other words if you ride your bike hard you can loose it on turns if tire are not the same rating :bigthumbsup: Be safe DO NOT TAKE ANY UNNEEDED CHANCES!!!!!!!!!!!!!! :doorag:
1 - 9 of 9 Posts
