1 - 7 of 7 Posts
I purchase my 9 from a guy that had already put a 2" lowering kit and 300 tire on it. When the bike bottoms or almost bottoms the inside rear fender rubs the 300. Has anyone else experience this and if so what did you do.
Thanks ALL
Do you know if he trimmed the rear inner fender? It supposed to be trimmed, if its not that is your problem.:bigthumbsup:
pm L.T.T., I know he did a lot of work on his inner fender.
Also the rear shock can be set up a bit stiffer, if your at 4 go to 5 and maybe 6 two up on the bike...
are there any visible grooves in your tire were the screws front the inner fender may have been rubbing?
if not you may just have to adjust your shock setting.
1 - 7 of 7 Posts
