1 - 17 of 17 Posts
I can't figure out what is going on with my 06 109. I have cobra swept pipes, PCIII, K&N filters and Duck covers. The bike ran fine last year. I took off the JSM as it went bad. My horse power and fuel mileage are way down. Mileage is down to 105 miles a tank. Changed fuel strainer and plugs. The bike rides fine, but does not have the pull it use too. Power is 86hp and 108ft torque. I have 13,000 miles on it. Any ideas or help would be appreciated. Thanks
:dontknow: The milage shouldn't have anything to do with it. I have 21,000 miles on a stock 06. It put down 108 at the wheel. The tq. would not record, but lets just say, it has a crap load of it:bigthumbsup:.
Check your throttle percentage through the power comander, should be 100% at WOT, or like V42 thinks disconnect the powercomander all together and see if you problem gets better.
Now if you are running really Rich you can wash out your piston rings and ruin your engine over time.
Check the connections like stated above if no problems are found sounds like you just need to re-flash the PC III.
Good Luck!
It was running lean before they dynoed it. It was backfiring. Now it doesnt backfire at all. How would I know if it is running rich? I know when they dynoed the bike the guy kept saying he could not get the fuel/air ration lines to get close to each other. He said the power lines were very close but fuel/air were not close at all. The bike is running fine but I can feel the power lose. It does not pull as hard as it did.
Power comander
My 109 has been sitting since I went too IRAQ. MY bike is running rich and at 27MPG. I had a cop come after me the other night and it seem to stuggel at 110mph. I've had it up to 150mph, But I don't think it will do it now.
I think it's the poer comander but I don't know how to reset it. Or if I just need a New one..
I'll take a poke at it, I've been wrong before, but did you adjust the power commander and dyno it WITH the JSM? Removing it afterward could foul things up a bit.
There is another possibility... Normally you will get some backfiring with this but not always... I would check your valve adjustment.... These engines seem to get tighter over time. I have rebuilt 3 transmissions now, and when checking the valves, one of the engines had to have 3 shims, it only had 28,000 miles on it.
LOL! Running from the cops is never a good time to find out you have engine problems. Here's a good slogan:
"Regular Maintenance......cause you just never know when you'll be running from the cops" :joke::joke:
If you were in Iraq, then you should be smart enough to know when the cops are chasing you and it's time to pull over. Nothing good ever comes from running.
Good thing you got away to tell your story! Right......and I happen to have a bridge for sale...interested?internetracer
:agree:
Good Luck!
1 - 17 of 17 Posts
