1 - 11 of 11 Posts
Has anyone else experienced this. It happened twice last night when I was twisting the grip pretty hard. The bike just nosed over at 5000 rpm. No warning lights or anything it just falls over then comes back. I am stumped as I checked things out and can't find anything abnormal besides the rider. Help :eek:
Yea mine has done it acouple of times, I just back out of it and get right back in it and it will pull like usual.........................when it does it I usual bitch at ECM for not letting me do what I want to do :D
Happens with mine too between 5-6K rpm, only when I crack the throttle though. My bike was originally overfilled with oil from the dealer and they told me that Suzuki informed them that it was a symptom of the overfill...oil getting sprayed in the airbox/cleaner. However, since having the overfill issue addressed, it has continued to happen intermittently. I just got my JSD-3M and hope that it cures the problem...otherwise going back to the dealer.
I don't know a lot about the mechanics of the 109 but it sounds a little like a weak Electric fuel pump or bad  fuel regulator (If it has one) or a clogged fuel filter or a fuel vent that is plugged??? :dontknow: :doorag:
Sounds like mine,maybe a fuel pump dealer is still not sure.Dose it run fine until you ride for an hour or so or dose it happen at start of rides?Mine would run great for about an hour then start
to sputter.
I t didnt' start till after the first service but it was after the bike had been sitting a week or so. It didn't happen imediately after the service just when I rode it hard Sat. night :eek:
Do you have a JSD installed?? My update to the product shows a sudden drop at 5500 when I engage the switch... But nothing when it's turned off.
http://www.m109riders.com/forum/index.php?topic=2901.0
1 - 11 of 11 Posts
