1 - 12 of 12 Posts
Thought I'd share what I learned today in case anyone else is experiencing similar problems...
My situation first started when installing my Fi2000R a few months ago because I had to remove the fuel tank. Through the process I incidentally pulled out a wire from the wire harness next to the fuel line before unclipping the harness. I popped the wire back in and my bike started and worked fine ... or so I thought.
Since, my bike would sometimes not start on the first try. Also, my bike would frequently sputter on decel and sometimes "chug" when rolling over small bumps in the road with a consistent throttle. Lastly, I noticed when turning off the engine, I would occasionally not hear the typical distinct last-sound of whatever it is that makes that sound (hard to type a sound).
Anyway, I had it in the back of my mind the wire came loose under my tank. Today, I took my tank off (attempting to resolve the annoying chirping noise) and noticed the wire was in fact loose. So, with the help of a dab of superglue around the wire, I securely popped it back into place.
My bike started without hesitation on the first attempt. Also, the ride to work today was noticeably smoother while riding down the poorly-paved county road. Basically, all the symptoms I experienced are resolved for now. I hope it stays this way!
Great, glad to hear you fixed the problem.:bigthumbsup:
Thanks for posting about this. More than a few have found a loose wire under there to be causing running problems.
That sound you hear when it shuts down is the bellows closing for the secondary throttle valves.
Ok Zoom, is there anything about the 9 you don't know? Just wondering if we should start a game and call it, "Stump Zoom" :joke:
Thanks for the info!
Been there , done that , towing $350.00
try the bike while up on towing, no go ,
towing leans the platform , this moves my gaz tank back
just a little , little enough for wire to make contact again
bike starts right away , $350.00 for nothing..:mad:
Yes Yellow wire going in connector , going out into a red wire
Bike cranks forever but does not start.???
I used a magnifying glass to look inside the connector
to make sure the terminal ""clicked "" in there ,before
I reunited both parts.
IF you push it in its proper place ,but upside down
the wire will not lock in place inside connector and
will come out again later , you have to hear it click
Yep, that's the wire... I think the yellow wire took the short bus. Anyway, good pictures, that's exactly the problem I had!
Hey! without guys like Zoom around all of us would be walking these nines around instead of riding them. Hail to all with the knowledge.:bigthumbsup::bigthumbsup::bigthumbsup:
Now you don't really think at my age that I can remember all that stuff, do you? :D
A service manual and a lot of saved notes my friend. And a little experience, and a lot of reading. And a little searching. Now I'm confused on what I was saying..... :dontknow:
1 - 12 of 12 Posts
