LiFePO4 Battery?
765 Views 7 Replies 5 Participants Last post by  smithy1
Anyone using a LiFePO4 battery in their Nine? If so, does it start the bike well? Any problems keeping it charged? How long did or has it lasted? Brand name?
1 - 8 of 8 Posts
Could be problematic. A LiFePO4 battery charged by an alternator regulator, I thought would likely fry the alternator.
I'm no expert on these batteries tough but looked into them briefly for camping when my lead acids clap out.
  • Like
Reactions: 1
They're finicky about charging voltage , too low or too high kills them. In cold climates they can be weak , so you leave the lights on for several minutes before you start the bike and it warms up the battery. They can sit quite a long time without being charged. When they crap out , it's all at once , no warning like a weak AGM battery , so sooner or later you're stuck. Then there's also the occasional thermal runaway/bonfire. I just bought a new Yuasa for my 9 , they're all I will use any more , even cheopo , off brand AGM batteries aren't worth the eventual aggravation.
  • Like
Reactions: 2
I never seriously looked at lithium batteries for the bike. I good AGM usually lasts me 3 or 4 years at least, and they cost 1/3 or less of what a lithium does. Other than the weight and size difference and the time they can sit idle, I just never saw the need for them. Great for power tools though. I've tried a few different AGM's but went back to Yuasa the last couple batteries.
Just quietly, I think he's trying to save weight. ;)(y)
  • Haha
Reactions: 2
I have not had good luck with AGM batteries. I don't find that they last any longer than flooded lead acid batteries, and in some cases they don't last as long. Any of my bikes that are in storage or not being used on a regular basis are connected to battery maintainers. I wonder if the charging requirements for an AGM battery are being met by the charging system on the M109R? Many battery maintainers and chargers have a way to select the type of battery being charged. I haven't had good luck with any Batteries plus Bulbs AGM batteries.
I've had a couple of their batteries and they both only lasted two or 3 years on two different bikes , with battery tenders in between and regular riding. That's why I've gone back to Yuasa , I've had others too in 53 years of riding and racing.
Have an SSB lithium in mine, been there for over 6 months now.... turns it over like a sewing machine. Lithium batteries are a lot better these days than they were even just a few years ago. Charging isn't a problem either as they have circuity in them which allows for normal charging...the bike doesn't know it has a Lithium battery. Have had the same battery in my BMW for over 6 years now and no issues in the cold either.
Smithy.
1 - 8 of 8 Posts
