1 - 7 of 7 Posts
brake
Look on the lever,there's an adjuster wheel,it alters the span of the lever,turn it to one of the numbered positions to get the span adjustment you want
Kuryakyn made a set of Wide Blade levers that looked like stock but were wider, and chrome. And they kept the stock adjustment on the brake lever. I have them on mine and also put them on my wife's S50. They are nice levers and only cost around $40 a pair. I think they quit making them for the 109 though.
I've only seen adjustable clutch levers for sport bikes. But you can kind of adjust yours by adding a shim between the perch and lever and readjusting the lever for the correct free play. Here's how I did mine to bring it back closer to the grips. This is a plastic push pin that is inserted into the cable groove in the grip. It brings the lever back about 3/8" closer to the bar at the lever end.
1 - 7 of 7 Posts
