i put a resistor i picked up at autozone on the lights to slow them down but the resistor gets very hot so is there something that will work better so i can mount it with out melting the bike
:dontknow:
Resistors do get hot, even the ones that you can buy just for this purpose get really warm. That's how they work, they dissipate the voltage by generating heat.
I put an electronic flasher on mine, but it will only work if you have LED's in front or rear but not both. It needs some amperage to make it work, so you need at least one regular bulb on it.
Here's a flasher that directly replaces the stock flasher. Several on here use it. You can find it on ebay.
http://www.lights4all.com/SUZUKI/LE...I-VZR-1800-INTRUDER-M-1800-R-06-09::1636.html
And a DIY from Robert Mays that works.
http://www.m109riders.com/forums/showthread.php?t=108627
So where is that installed it looks like u just plug it in??
Hey, go with"light4all",,, the flasher is located under the battery box on the left toward the front,,,this is easiest way to do it,,,
Yes I agree
I bought one and it works like it claims, I do have one forsale that came with my intergrated light from Clear Alternatives if you want to purchase it. Its not a resitor but a true flasher relay. Price 35.00 plus shipping. You may want to call CA and see if you can purchase one seperately, I may be over pricing it let me know.
ended up going with lights4all and got the flasher relay unplug and plugged the new one works great and i didnt have to worry about the heat issue or the extra wire and space. thank you guys :clap2:
