1 - 6 of 6 Posts
Has anyone here ever used The Blue and the white paints in the spray cans for the 07 LE? I might have found a fender. But it is not the LE. If I paint it myself using the recomended base, color, and Clear will it match?
Thanks for any and all info on this in advance!!!
Kenny
Kenny
I painted a few things on mine, Look in my profile pictures. Doing the fender make sure you get the right primer. it is a white color, I started using gray and the final color wasn't matching perfect. They have a 2 part clear that is chemical and gas resistant. I still have mine. didn't use it. I just used a can of acrylic enamel crystal clear it is called. Pretty good stuff.
i used the colorrite.... black, and it didnt match... no metal flake in it... better off spending the extra money and having it done... well worth it
That's what I did. I had my painter at the body shop do a scan and match it. The colorite did not match. It came up lighter. And I had the painter at the body shop spray it.
Hey bro , what are you needing? I am going to change my paint scheme this winter , will no longer be the blue le, I will trade you a panel for panel and you wont need to paint. My panels are all perfect . Let me know.
1 - 6 of 6 Posts
