1 - 7 of 7 Posts
I am order a set of Kewl Metal 2 inch risers and I am wondering do i need to order 3 in clutch and throttle cable pull and push lines? And also do I need to get the 3 inch front and back brake line kit. I am ordering stainless steel lines and the guys a DLP said I would need the 3 inch clutch and throttle lines but are unsure about the brakes, I would understand the front brake line but not an ext. for the back but they only come in a kit regular or 3 +. Help me out.
http://www.directlineparts.com/byProduct.asp?prd=Brakes&str=290
http://www.directlineparts.com/byProduct.asp?prd=Cables&str=290
I did the clutch and throttle cables (both ) didnt do the brake line just removed it from the block . I plan on doing it just to improve the over all braking .
Ok so are you saying you changed the cables to the 3+inch and you are going to do the brakes to the 3+inch in the future. Or you just keep stock?
It will work by rerouting the cables and removing the mount at the the brake line manifold (at triple tree). There is a video on here somewhere showing how to do it and reroute your cables.
JG and Lee Thanks I am going to order the 3 inch plus Throttle Push/Pull and Clutch cables and the original length front and back brakes lines all in Stainless steel.
The stock length brake lines work just fine. Remove the bolt that holds them behind the headlight and let the block float. I have the 2" risers on mine and the stock length stainless cables work fine. You do want the +3" clutch and throttle cables for them to fit properly.
1 - 7 of 7 Posts
