1 - 15 of 15 Posts
It stalled and made a strange noise i pushed it back home. And let it sit for a while went outside and started it again.And when i tried starting it backfired.I tried again and it started .Now i am hearing a tapping noise sounds like it is coming from the right hand side of the engine into the exhaust.And before this happen last week it lost full clutch engagement.I was test driving before i took it to the dealer whoops i mean the stealers.I am so in love with this bike and i just bought it.Its a 2008 le m109r with 2600 miles on it.And it is making me loose hair.
I would have to imagine even a used bike has at least a 30 day warranty. It could be a gamete of things, sometimes you just need to start testing and eliminate things untill you dind out what it is.
Backfire could mean exhaust leak
I also have a ticking noise when warm, and it is not the clutch basket it sounds like a header tick. if you ever had leaky headers on a V8.
I also have the safest color 2008 le, That bright yellow is a very good pick to be seen.
After talking to 07diesel on the phone, I think this is a tube nut issue. The clutch will not fully disengage... He is going to tear into it, and get back to me. Good luck bro!
Just started i had to heat the exhaust bolts up by letting the motorcycle run for a bit cause the bolts were stubborn while it was cold.I figured they had loc tite on them and that would warm that stuff up.And it did so i have the exhaust off.Tommorrow ill jump into the basket. I hope its something simple like that loose bolt you are talking about.Cause i really am ready to ride.Thanks bro.Thank God for the true Americans :clap2:
Hink, You are seriously a stand up dude! Diesel, Good luck man, keep us posted!
I'm pretty sure that there is not loctite on them. And if there was I would think it would be the red version. More heat would be needed. Try spraying some penetrating oil on the bolts.
Lord knows Hink has had plenty of experience tearing into the clutch side of this thing. :D
And he is a standup dude, many can vouch for that. Glad you got the exhaust off as there have been a few posts recently about them breaking off.
1 - 15 of 15 Posts
