1 - 5 of 5 Posts
I just put new turn signals on the rear. They are chrome mini 1 LED s by shock racing. Got them from J&P Cycles. they look great. But, when i turn the key on and the comp goes through it's cycle, about 2/3s of the way through there is a loud squeek. Awful sound. And the signals flash rapidly, as they do if there is a burned out bulb. Anybody ever have this problem or hear a similar noise?
Squeek is your SET valve, dont worry bout it....
Lights... Dunno, check your work. Most likely you need a load balancer thingy
Okay, thanks Reed. I found some posts that address the flashing issue when using clear LEDs. The resistor should fix that problem. :bigthumbsup:
As far as not worrying about the squeeking set valve, I don't know. It sounds like sheet and hope it goes away!
1 - 5 of 5 Posts
