Is servo needed to run stock exhaust?
862 Views 32 Replies 7 Participants Last post by  Bering_C_Sparky
Hey All,
I am thinking about purchasing some stock pipes for my 08. I bought the bike with a side-burner, but even with a home-made baffle it's louder than I want. My bike has a servo eliminator and a TRE. Can I run the stock pipes without the servo?
Thanks,
Danny
1 - 20 of 33 Posts
Yes they can.
Just be sure the set valve spring on the exhaust is intact and holding the set valve in the full open position all of the time.
BCS
LGB/FJB
  • Like
Reactions: 3
Default position is the valve is full open. The computer closes it at start up.
  • Like
Reactions: 2
A side query. Has anyone done a comparison with operating as it should and with SET valve constantly open?
I'm very keen to see a dyno comparison.
We used to have a 'Dyno Test" thread on here where members posted their dyno test results. I don't recall anyone ever doing a comparison between the SET fully open and SET functional though. I know it's slightly louder at idle and low speeds with it disabled and open all the time. I know the purpose of it is supposedly to enhance low end torque, but I think it's probably done as much for noise control as anything else.
Another thing I always found odd about it was it's supposed to enhance low end torque, then they reduce the timing in the lower gears to decrease torque. Not sure of the logic behind that.
  • Like
Reactions: 1
99.9% of all dyno graphs you will see are done at 100% throttle position.(WFO)
So you will see no difference at all with or without the SET valve functioning on most dyno runs.
Unless you were to do them with & without the valve, both at the exact lower throttle position, its not going to give you any usable data for comparison.
The Set is open all the way at higher throttle positions, so it is the same when the servo is disabled and the valve is open all the time.
I agree with Zoom's statement above
The main reason manufacturers install the exhaust valves is to reduce noise at lower throttle positions to meet government guidelines and keep the city dwellers from complaining.
If they were installing them for more power or torque then they would not also restrict the ECU in those areas at the same time.
As far as the comments about restricting the exhaust for more low end torque. If these mods are static, then you are also killing your top end at the same time.
Which is why the SET has a servo module to open the valve at higher throttle positions.
But then again, Suzuki limits the top end in the ECU as well......I think the engineers might be bipolar. :)
BCS
LGB/FJB
See less See more
  • Like
Reactions: 3
BCS, regarding the comment about the SET valve and full throttle. I was wondering, does the SET valve open solely in response to throttle position, or is it also rpm related? I was thinking if it was also rpm related (valve wouldn't open fully below a certain point) that it would show up on a dyno graph since they record from lower rpms too.
I have no idea but I figured you had done enough dyno runs and ECU work to know if there was a relationship. :)
  • Like
Reactions: 1
I thought the same thing. Just wondering if there are gains in torque at lower (useable) rpms, then as you roll it on, the valve opens as you trans into the higher rpm ranges. My thoughts are (in a run) that it would help a little in first, noting I hold near 3000 rpm and at take up point, then more or less drop lever as I roll it on further.
Well to be honest I have never seen any written spec stating that anywhere and the software I use to flash the ECU's does not reference or data log the exhaust valve position feedback. Its racing software, so the stock exhaust is not a variable. It is usually hanging from the rafters in the garage as a decoration.
Easy enough to see in real time if someone who has a stock exhaust wanted to test it out though. Just connect a voltage meter to the EXCVA position sensor and give her a rip.
But logically you would expect it to be fully open well before that point.
The secondary throttle plates are at 100% way, way long before then and the fuel map value for the injector pulse width is just as wide at lower RPM as it is in higher RPM's when you get into the upper TP ranges.
So it would not be logical at all to have the intakes wide open bringing in as much air as possible and the injectors pouring on the fuel, but then purposely have the exhaust dampened down, instead of free flowing.
We would be slipping back into those bipolar engineering ideas by doing that.
If there were even the slightest gain to be had at WFO by doing such a thing, the pro drag vehicles would have it incorporated in their exhaust.
You can bet the farm on that.
BCS
LGB/FJB
See less See more
  • Like
Reactions: 3
I can only state, that, seat of the pants, when I took my stock exhaust off in 2010, and went 2-into-1 Cobra, I didn't notice any drastic loss of power. It still gets all loose and the back tire gets going side-to-side with a ten inch rim and 280. just like it did before with the stock exhaust and smaller 240 tire.
  • Like
Reactions: 1
Thanks BCS and CB. I figured (nearly) as much, but better to be well informed than not.
The thought crossed my mind in so much as I thought there might be some potential gain to be had.
I'm still running the stock, gutted exhaust for now. Was looking at VP's but have heard a little bad feedback.
The only issue I have personally seen with the velocity pro is the heat shield cracking over time.
Honestly I believe this may be due to bad motor mounts causing the engine to buck and move more than intended and not a actual flaw with the exhaust.
I have been running the VPR exhaust for a few years now and my heat shield has cracked on the rear header pipe.
And yes I do need motor mounts done on my bike, but have been putting it off for way to long now.
The only other type of complaint I have heard, is one guy from Australia posted that he order one and the paint did not hold up or something like that.
But he is the only one I have heard make that complaint, so possibly it was an isolated incident.
Mine is chrome so no issues with paint on exhaust there.
I really like the VPR exhaust myself and would not hesitate to purchase another one.
I may contact Hard Krome and see if I can purchase a new heat shield for it. If not I will either remove the heat shields and wrap the exhaust or just purchase a new one. (or maybe both eventually)
But I have 6 or 7 other exhaust hanging from the rafters at the moment, just waiting their turn to go on the bike. So will have to see what direction I end up going next, who knows? Have been so busy lately I rarely get a chance to ride at all.
We also have many customers who purchase ECU tunes for the Velocity Pro exhaust, so they are popular in the 109R community for sure.
BCS
LGB/FJB
See less See more
I'm pretty set on VPRs but I tend to hesitate whenever a red flag, however slight, pops up.
So, being from Aus and noting the other guys comments about chrome work degrading, and no customer support "what so ever", I have been holding off. If I could find one for sale over here, I'd look at it for sure.
Hey B, are you running long or short?
Thanks BCS. Back when I had a stock exhaust I never thought about checking voltage, but I did take the cover off that conceals the actuator and then tried hitting the throttle to see what it did. I couldn't tell by doing that exactly what was going on, sometimes it seemed to flip open almost immediately and other times it seemed to have moved just partially open. And when returning to idle it would sort of flutter before it returned to the position it had at idle.
I have the VPR (short velocity pro) on the bike now.
But I have also had the long version velocity pro on the bike some years back as well.
I also have a sideburner exhaust, which is the same as the velocity pro, except it turns out to the side instead of being straight our the back.
The sideburner is made in a long and short variety as well.
You can also look at the Freedom Performance Combat 2 into 1 exhaust.
It is a little longer than the short velocity pro, but a little shorter than the long velocity pro, and it looks good on 9 as well.
Below is the Meancycles link with just about every exhaust for the M109R out there.
BCS
LGB/FJB
See less See more
  • Like
Reactions: 1
Champ.. Cheers 🍺 ;) (y).
I'll check them out.
Have you found one to be better performing than another?
Here is the long and short velocity pro on Big Bird side by side for comparison.
They are all about the same honestly.
Just get the exhaust that suits the look you want for the bike.
I will say that if your ride 2 up, your passenger will appreciate the longer pipe more.
But personally I like the look of the shorter pipe better.
BCS
LGB/FJB
Tire Wheel Vehicle Automotive tire Automotive lighting
See less See more
2
Here is a couple of my 07 as well with the Velocity Pro Race (shorty) and Richards 07 with long straight 2 into 2 pipes.
And my 07 with Cobra Swept 2 into 2.
BCS
LGB/FJB
Tire Wheel Land vehicle Vehicle Plant
Tire Fuel tank Wheel Vehicle Automotive lighting
See less See more
I do like the look of the VP short. Long looks good too. I never carry a pillion, that's what either the GS or the Strom is for.
I keep the 9 just for my riding pleasure. Wait, that doesn't sound right :unsure:. The M109R is for my, uh hum, entertainment (y).
I would be keen I think for the shorty.
1 - 20 of 33 Posts
