1 - 5 of 5 Posts
Is it possible for the M109R to be extended????? Me and some friends were debating this issue just want too see what some of u think......I personally think that it could be done and it would look hott extended.....
ANYTHING is possible with enough money. The shaft drive on the 109 will make it far more difficult then say a chain or belt drive bike where you only need a longer swing arm and chain or belt.
What about triple trees that extend the angle of the front forks. That along with the lowering bones will give the impression that it is lengthened. As far as stretching the frame, anything is possible. You would definitely need a longer tank or some sort of filler or extender or a custom seat to fill the gaps. I like mine the way it is. If anything, I'd switch the triple trees out.
1 - 5 of 5 Posts
