1 - 11 of 11 Posts
I installed my 2in risers and when I was done the throttle side cables are way to tight. The cables are ok when turning left and when they are straight but I can't turn the bars to the rigth that much. How can I get some more play in the cables without replacing them.
You can't.
Well I rerouted the cables and I was able to turn the bars but when I started the bike and turned the bars the throttle got stuck. So I took the risers off for now and I will work on it this weekend when I pull my wheels off for my new 10in and 280 and 160 front.
You dont need new cables just reroute them behind the triple tree. I put 2 inch risers on my 08 and put hundreds of miles on with no problem.
You rerouted your cables but did not adjust them afterward?
That is my guess.
Sure, you can gain quite a bit of room by rerouting your cables.
Once you have them where you want them, you need to adjust them to get the proper tension for the new route.
Not a big deal, just play with the adjustment until it moves like it should.
:agree: I also added the 2" longer risers and re-routed behind the triple tree with no problem.
I hope you already know there is
no need to remove the triple tree to reroute throttle side,
( same for other side )
just undo the housing of the starter button and remove end cap
you can slide off the throttle and reroute it .
when I did mine the tutorial said to remove triple tree
but I didn't .I have the stock cables with 2 inch risers.
Want 2" Risers and use Stock Cables, not a problem...
For the nay sayers who believe that you cant use 2" risers with stock cables, here you go:
I used a small piece if 1/8" aluminum bar stock to locate the brake hose tee up ~1". Dunno if it was really needed in the end, but I think Big Poppa suggested it, and there is plenty of slack. I taped one hole M8-1.25? to hold a bolt put through the hose tee and drilled a clearence hole on the other end to re-use the stock bolt to hold the aluminum bracket.
For the clutch side, I re-routed the cable on the outside of the engine mount and frame rail. To do this, I had to remove the clutch chrome cover and disconnect the cable and lever arm.
On the throttle side, I took the throttle off the handle bar (remove end cap and three screw under the starter switch housing) and routed it under the triple-tree. (no need to take the triple-tree off then) When I did this, I routed the cables over the brake hose, and they do not rub at all.
To finish it all up, I used a few small black zip ties to hold the cables, wires, and hoses together. Cleaner look and more prevention of things rubbing. (see drivers view)
Take care,
Shane
1 - 11 of 11 Posts
