1 - 4 of 4 Posts
The owners manual say's that the idel speed should be between 800 - 1000 rpm's. Mine idle's when in gear between 1200 - 1500 rpm's. If I take it out of gear and drop it into nuetral, it drops down to 1100. Has anyone else had this problem?
That's not normal at all. If the bike is in gear with the clutch in, the idle should be around 900 to 1000 (based on my own experience). Even the JSD-3M doesn't keep the idle that high with the clutch pulled in... only when in neutral and the clutch out does it go to 1100-1200. If you don't have a JSD mod installed, you should take it to the dealer because something isn't right.
1 - 4 of 4 Posts
