1 - 3 of 3 Posts
I'VE GOT JUST OVER 1000 MILES ON MY BIKE. NO PROBLEMS UNTIL THIS MORNING GOING TO WORK. I ALWAYS START MY BIKE AND LET IT IDLE FOR A FEW MINUTES BEFORE TAKING OFF. I TRIED CRANKING IT SEVERAL TIMES THIS MORNING AND IT WOULD NOT START (OUTSIDE TEMP 74). FINALLY, I GAVE IT SOME THROTTLE AND IT STARTED. ALL THE WAY TO WORK EVEN AFTER THE ENGINE WAS PLENTY WARM, THE ENGINE WOULD DIE AT IDLE. IT RAN GREAT ABOVE IDLE. IT USUALLY IDLES AT 900 RPM, IT WOULD TRY TO IDLE AT 400 THEN DIE. I DID FILL UP AT EXXON ON MY WAY HOME YESTERDAY...COULD I HAVE GOTTEN SOME BAD 93 GAS OR IS THE COMPUTER THAT CONTROLS THE ELECTRONIC FUEL INJECTION AND IDLE OUT OF WACK?Â
ANY HELP OR SUGGESTIONS WOULD BE APPRECIATED. THANKS.
I would suspect the gas. I would put some dry gas in the tank, and see if that solves the problem. If not take it to the dealer. If something has block the fresh air system(emissions not air cleaner) it will not idle.
do you have that jsd mod it could be going bad :confused:
1 - 3 of 3 Posts
