1 - 7 of 7 Posts
Hey guy's, I just got some chrome fork tube covers upper/lower.:clap2: Do anyone have these on their bike and is there a how to out here. I thought that they where the kind that you just stick/bolt on but it looks like you have to do some mechanical work here and that is not my cup of tea. I'm willing to try if I know that I have the right info and tools but with these weak instruction I will not get caught scraching my head. :dontknow:
all you need is the lift and hexagonal wrench..you open the triple-tree bolts (upper 1+1 and 2+2 lower)..then pull the forks out, put onto the lower chrome tubes, push fork back through the lower triple-tree, install upper tube and push the fork to it's original position, tighten the bolts and your'e done..:dontknow: (just be sure to put something under rear wheel first as the front end becomes very light as soon the fork is released..)
very easy to do just make sure you don't forget to put the rubber o-ring gaskets on to keep the the fork tubes from rattleing and moving!!! i love mine111
Dude I love the custom rearend on your bike and the slammed bobbed rear fender!!!!
It's not that hard, just a little time consuming, especially for a first timer (like I was). Just mark and separate your bolts/screws. Oh, and remove the front wheel, it makes it a lot easier, especially if your doing it alone.
:bigthumbsup: Thanks guys, I think I will give it a shot this weekend. Be on standby in case I get overwhelmed !!! lol !!!
1 - 7 of 7 Posts
