1 - 10 of 10 Posts
I cranked mine up and was pissed when it started leaking again. :edit: So I did the only logical thing and decided if I caught on fire it was worth it because the dealer couldn't find the leak. I left it running and started taking apart the bike. I found the Fuel injector on the left side leaking at the o-ring where it goes into the throttle body. I just pushed it in and leak stopped. Not a permanant fix but will last while dealer orders my o-rings. Anyways I have seen a lot of posts about this so I hope this helps. :bigthumbsup:
Sweet find bro! THanks for the info, noticed the smell of gas while riding mine a couple of times also. When I get home later this month I'm hoping NOT to find a puddle of fuel as so many others have posted about. If I do at least I'll have a place to start looking.
Update: Oct 21: Found no gas on the bike, had a full tank when I left, full when I got home. No smell of gas either... Guessing I spilled some on myself or the tank and thats where the smell was coming from.
Mine did it this morning...it seems to be dripping slowly from underneath the left airbox....there are 2 metal tubes that are small in size that come from underneath
it ...were it seems to be concentrated from...gotta go to work now but I'll investigate further.
Hey just wondering if you could pin point the o-ring you are talking about in the manual if it has a blow up of the diagram or from the parts list online Alpha I think it is. I have often smelt gas at different times and if it every becomes to be a problem it would be great to know where to look. As you can probaly tell I am not that familliar with alot on the bike so if you could pin point it that would be great, Thanks the same :bigthumbsup:
Thanks Bro :bigthumbsup:
Mine leaked from number 14 from above, the clamps on both sides had to be replaced. The left side was easy I had to remove the airbox on the right side to replace it :'( :'(
Thats what the stealer is currently replacing on mine
1 - 10 of 10 Posts
