1 - 6 of 6 Posts
well I went to A busa from my m109 to a harley springer ,yes the dark side then wifey said she want it, and now this is my latest project problem is everythings already been done hmmmmm. I'll think of something .But I will always belong to this fraternity .....
YAMAHA ROADSTAR XV1600; HERE `S A LIST OF THE MODS...
- J&E 10.25 PISTONS
- JUGS CUT .020
- HEADS CUT .010 ESTIMATED COMPRESSION 11.8
- PORTED HEADS ,NEW VALVES,NEW GUIDES, PATRICK RACING SPRINGS, NEW VALVE SEALS, SEATS RE-CUT
- PATRICK RACING CAMS AND LIFTER KIT, WITH ADJ. PUSHRODS
- NEW ROCKER ARMS AND SHAFTS, NEW LIFTER BLOCKS
- FALICON SUPER CRANK, CRANKSHAFT WAS LIGHTENED BALANCED APPROX 7LBS.
- CONNECTING RODS STRENGHTENED AND SHOT PEENED, NEW ROD BOLTS AND BEARINGS
- HEAVY DUTY OIL PUMP GEAR
- EFM AUTO CLUTCH, NO CLUTCH LEVER, NEW CLUTCH PLATES
- YAMAHA TRANSMISSION WARR. UPDATE, 4 OTHER GEARS REPLACED
- ALL NEW SHIFT SHAFT SPRINGS, DETENT SPRINGS , SHIFTS LIKE NEW
- ROADSTAR WARRIOR CLUTCH COVER
- ROADSTAR WARRIOR CAM HOUSING AND OUTER COVER
- ROADSTAR WARRIOR STARTER MOTOR, STRONGER THAN STOCK, CHROME
- RIGHT SIDE STATOR COVER CHROMED
- HIGH FLOW INTAKE MANIFOLD WITH PORTS MATCHED
- POLISHED MIKUNI HSR42 CARBURATOR
- D&M VELOSITY STACK
- DYNA IGN. COILS AND WIRES
- DYNA 3000 ADJ. IGN BOX
- HIGH OUT PUT YUASA YTX20HLBS BATTERY
- AMZOIL 20W50 MOTORCYCLE SYN. OIL, AND AMZOIL FILTER WITH 200 MILES ON IT, OIL CHANGED EVERY 1000 MILES
- 18 X 8.50 DNA 60 SPOKE. TUBELESS AVON 250/40-18 VENOM RADIAL
- 18 X 3.5 DNA 60 SPOKE TUBELESS AVON 130/70-18 VENOM RADIAL
- PERFORMANCE MACHINE FRONT ROTOR AND MATCHING SPROCKET POLISHED
- EK530 ZZZ CHROME CHAIN
- YAMAHA V-STAR 1300 FRONT AND REAR FENDERS MODIFIED
- FRONT FORKS HAVE RACETECH GOLDVALVES AND PROGRESSIVE LOWERING KIT
- RIGHT FORK LEG HAS BRAKE CALIPER MOUNTS REMOVED & CHROMED
- ALLOY ART HEADLIGHT-PANLIGHT CHROME
- MIDDLE FORK COVERS FABRICATED DESIGN THEN CHROMED
- HANDLEBARS HAVE THREADED SLUG WELDED IN FOR MIRROR
- MATCHING SUPREME LEGENDS GRIPS AND FOOT PEGS
- ACCUTRONIX 4" RISERS DRILLED FOR THROTTLE CABLE
- AUTO METER 5" MONSTER TACH WITH REPLAY
- FABRICATED LOWER TRIPPLE TREE COVER-CHROMED
- INTERNAL FORK STOPS
- TOP TREE HOLES WELDED UP ON FRONT & CHROMED
- INTERNAL THROTTLE WITH CABLE THAT EXITS BELOW TOP TREE
- STARTER BUTTON & HORN RELOCATED UNDER LEFT SIDE OF TANK
- NO CABLES OR WIRES ON HANDLE BARS
- SUPREME LEGENDS FORWARD CONTROLS WITH SHIFTER MODIFIED AND HAS ROLLER BEARING IN SHIFTER INSTEAD OF BUSHINGS
- REAR BRAKE PEDAL ACTUATES FRONT & REAR BRAKES TOGETHER
- FRONT BRAKE LINE HIDDEN IN LEFT FORK COVERS
- FABRICATED REAR BRAKE ASSEMBLY ON FRONT COUNTERSHAFT SPROCKET WITH 4 PISTON JAY BRAKE CALIPER.
- FRONT STOCK CALIPER CHROMED WITH EBC HH PADS FRONT & REAR
- SWING ARM MODIFIED TO ACCEPT 250 TIRE AND TO HAVE BOTH SIDES MATCH, STOCK REAR SHOCK WITH ADJ. LOWERING KIT
- FABRICATED VANCE & HINES PRO HS PIPE SHORTENED HEAD PIPES TO COLLECTOR-SHORTENED REAR SECTION WITH CUT DESIGN.
- THEN RECHROMED, FABRICATED BAFFLE. SOUND IS INCREDIBLE!
- COLOR IS A STOCK 03 ROADSTAR COLOR, DEEP MOCCA (EVERYONE CALLS IT ROOTBEER). FRAME IS PAINTED THE SAME COLOR.
- YAMAHA ACCESSORIES INCLUDE: RT SIDE BALL MILLED CHAIN CASE COVER, SWING ARM PIVOT COVERS, REAR AXLE ADJ COVERS, CAM
- COVER, LEFT CLUTCH COVER, LEFT GEN COVER, STARTER END CAP COVER, TIMING HOLE COVER, FORK CAP COVERS, COMFORT CRUISE SOLO
- STILETTO SEAT, IGNITION SWITCH BEZEL, EDELBROCK 12 OZ NITROUS BOTTLE USED FOR SHIFT LINKAGE
- PAUL YAFFE LICENSE PLATE, LED
- NEW STEERING HEAD BEARINGS
- NEW SWING ARM BEARINGS
Really like that paint job on the busa, im normally not a flame guy but those are freaking cool. Sorry but the hd does nothing for me at all but if you liked it thats all that matters.
You have had some nice bikes for sure, I would rank them
#1 busa
#2 m109r
#3 roadstar
#4 springer
cost of bikes would prob. be exact opposite
I would ride with you no matter which one you where rolling on
#1 busa
#2 m109r
#3 roadstar
#4 springer
Thanks buddy my girl getting the springer jus have to put it back n the shop to set it up for her new sit handlebars paint ,the road star im not sure what to do the busa i would have died on it and m109 now has a good home. I wil b at the next event u all have buddy count on it
1 - 6 of 6 Posts
