To answer the above question correctly, it is approx. 638-640ml for the correct amount to put back in. We put Garthen's forks back together after getting them back from chrome. To put it at the correct height of 133mm down (which if you read the above post Suzuki is extremely vague on where to measure from) you just add roughly 640ml and follow the procedures for getting the air out of the system. You will be with in 1mm of the correct height. You see, all the other manufacturers will give you a fork oil capacity to get you very close. Well I did it for Suzuki since appearantly it is a huge secret. You will not find it anywhere in the manual. So, for those of you who can do this work yourself (forkseals, fork oil replacement, rebuild forks) you might want to write this amount down in your manual on chapter 9 page 20. This will save you alot of time.
