1 - 20 of 20 Posts
I recently had my 109 in for repairs. My rear rim was dented. They fixed the rim, and it now has a lead weight stuck on the inner circle of the rim.
Anyone else have weights on their rims.
I have three small square weights stuck on the shaft side of the rim. They were put there when I had the Metzeler installed. I think there was one small weight on the edge of the rim from the factory.
Both front and rear factory tires had weights but my new rear Elite 3 250/40 R18 has none and I've run it over 140 mph with no vibration so I guess it just doesn't need any. Bastards scratched my rim pretty bad though . :edit: .....is there no way to avoid this ? I've been asking around and it seems to be just the way it is here .
Dave
Sounds like most do. I was a little worried that they added so much aluminum that they had to throw on too many weights.
Now I just have to deal with the difference in color from stock to what they have painted them...
No weights on mine !
Far as scratches go I think that can be avoided,i have watched tire guys mount some High profile rim's and they used a Teflon coated tire bar,Not the regular steel one used on every day car rims!  I guess it's called Teflon it's white plastic looking stuff keeps from messing up a high dollar rim :bigthumbsup: some people do not have the love for motorcycles we share here!
You guys have me wondering, to the point of concern??
I've one small weight on the front wheel and there isn't any on the back one. I've had the bike up to fairly high speeds (80-100mph) There doesn't seem to be any great vibration. Do I need to have the back wheel balanced,
to see if it needs weights? The dealer says that they are balanced at the factory and if the front has weights and the back doesn't. Then the rear didn't need any.
This dealer has been wrong before.
Jeez guys, don't you understand what the weights are for? ::)
Not all tires are balanced correctly, i.e. the rubber may be a little thicker/heavier on one side of the tire than the other. That's why every time you put a new tire on the bike they will remove the weights from the wheel and reattach however many is necessary to balance the wheel with the new tire on it. Sometimes you need weights, sometimes you don't. Don't sweat it. I would be more concerned if I DIDN'T have any weights on my rims, wondering if they skipped the balancing step and am I running an unbalanced wheel? :doorag:
I originally asked, because they recently repaired my rim, and I saw some honkin weights on the rear. I was concerned they really messed up the balance of the rim, and are over compensating with too many weights.
Although the weights on my rim are big, sounds like it's probably within reason.
I think most know weights are for balancing.
1 - 20 of 20 Posts
