1 - 20 of 33 Posts
Just wanting to get your guys opinions. When riding at night, when you meet a car do you dim your lights or just leave on the high beam? Seems that when I dim my light I cant see s#$t.
It depends really. If someone flashes me I will dim the lights. I run with my bright and my little Walmart driving lights on.
I always close one eye when passing an oncoming car at night so there is less time to readjust to the darkness.
Always dim, it's the law.
If I have issues seeing far ahead, I "drive by the line", pay attention to the white line while visibility is lower in the distance. If there is traffic coming toward you, you can use their lights to see also. A combination of all of the above gets me through.
Running your high beams is just asking for trouble, not to mention a ticket.
May I suggest adjusting your headlight up a little if it's that bad??
:agree: I adjusted mine up alittle and use a different bulb with a whiter light beam.
I ride with my highbeam on during the day, but at night I use the headlight as I would those on a car. You don't leave your highbeams on when you encounter an approaching vehicle from the opposite direction, do you? It's very inconsiderate if you do.
I hate getting high beamed, and I know its the law but I would rather high beam someone than run off the road in a curve because im tring to be curtious.
If you can't see with your low beams you either need to get your low beams re-alighned or not drive at night but yes go from high to low when you see an oncoming car. Not only is it the law but if you blind him and he swerves into your lane, your screwed anyway.
Before I installed my HID light I would dim to low beam. Since the HID is so much brighter than the high beam I dont. Actually not many cars will flash me with the high beam on so it probably isnt that bright anyway.
Just leave the high beam on and see how many people flash you back.
:cop:I know, I know its the law. I do dim when meeting a car just wanted to get the opinions. As I said I hardly ever drive at night but am considering upgrading to the HID kit. Wow didnt think I would so much good input:bigthumbsup::bigthumbsup:
1 - 20 of 33 Posts
