Hey,
I installed my HID kit. Looked great, was super pumped to test them out tonight. Noticed a flicker as I pulled out of the driveway, noticed a bigger flicker about 100 ft down the road when i shifted into second, made a corner and then the lights flickered again and then cut out.:edit: Got the bike home, turned it off, started it up again in the garage light looked fine - no flickers.???
Checked the connections, checked the ground and power wire they're all tight. Checked the mount for the blub noticed it was loose, so I tried a little bit of krazy glue so it wouldn't move around the socket anymore... seemed fine. Hooked it all back up... same issues.:edit:
Any hints on this? I'm leaning toward a viration issue with the bulb, but has anyone else had any issues??
Thanks for any help - Kev
