i got yana shiki lowering bones for my 09, and the bolt holes are a bit larger, do i just grease them and put it back together or do i need to find a bushing to install????
:agree:What size did you get? If it is the 2" or 3" they do not use a bushing. Just the stock bolts and grease them up with a good grease.
:agree: I've got the 2" bones. greased and installed.That's the same bones I have and you just grease them up and install them. The hole is a little larger than the bolt, but not large enough to put a bushing in them.
