1 - 6 of 6 Posts
I would appreciate some help from you guru's out there.
I need a bolt from rear of bike, under cowl/rear seat there are 4 bolts total, two different kinds. I need one that is farther to the rear. About an inch long but half is threads and the other half is not.
I need plastic push pin for plastic side covers...right under drivers seat.
I also need plastic push pin for battery cover.
Can anyone help me out?
J
also, i have no knowledge of what terms should be used, so bear with me.
Thanks, i got the part number i think. When buying them its gonna cost about 10 bucks for what i need plus extras. The shipping is going to be 16 bucks. CRAZY.
Ill head to the shop to see what i can come up with.
You could probably check the local auto parts store. I used to replace windshields for a living and there are hundreds of different pushpin type fasteners on cars. Even if you don't find the exact same thing, you'll find something that will work.
I picked up both sizes at the local motorcycle dealer. I got a box of ten of both sizes for around $8 each. I would ck there first. As far as the bolt, I am assuming you are talking about the one that has a shank on it? The forward is fully threaded. As far as that goes you could get one that would fit from a local hardware store but more than likely wont have the shank on it. You might just end up having to order that one. Hope this helped.
:agree: :agree: If you go to Onieda, as you know they charge out the butt for shipping small items. And, it sometimes takes a week to get to you. The local dealer will mark up the product more, but you don't pay for shipping. In addition, my dealer always has my part in 2 days.
1 - 6 of 6 Posts
