1 - 5 of 5 Posts
does anyone have pics of a rear wheel removal? I need some new rubber on the back and would like to try removing the wheel myself. thanks for any info.
thanks KC...I already read that post but no pics....I think I can handle it after reading that but I just wanted some pictures to see how the final drive gears work.
Witnessed it yesterday. Pretty cool. My tech used a REVERSED spark plug wrench in the axle hex. Said he didn't need my tool I bought. He said it's a great secret instead of buying the Suzuki tool bit. The rear drive system is pretty trick. Kinda wish they could have had a beefed up single sided arm.
Set the caliper as far out of the way as possible to avoid scarring the rim. No need to remove pipe. Torque from the Hex side. 72 ft lbs if I recall correctly.
1 - 5 of 5 Posts
