1 - 6 of 6 Posts
i got the bones off and i noticed the stock bone has a bushing and a set off bearing inside, ok i put just the bushing with grease and it is very tight to move back and forth is this normal i would think the bearing and all the stuff would need to be transfered over to the new bones. the bones are the raw performance adjustable ones ??????:dontknow::dontknow::eek:
ok just making sure better to ask now while its apart then to find out later :doh::doh::doh::doh::doh:
:agree::agree::agree:
i do want to say if you put the floor jack just forward of the end of shock when you jack it up it will wobble so strap it down and that shock pivets all the way down and out of the way had no problem what so ever getting the bolts out then i used a extension through the outer bone bolt hole to get the inner one loose like someone told me and it worked like a charm and yes this forum has saved me alot of headaches and worries
:clap2::clap2::clap2::clap2::bigthumbsup::bigthumbsup:
1 - 6 of 6 Posts
