The really odd part is that he is not getting any FI fault indication at all.
Might want to pull the connector off a sensor and start the bike just to make sure your FI fault indicator is actually working.
If there were issue with the crank position sensor, I would think the bike would run very bad, as in most likely not at all.
If the crank position sensor is off you're not going to inject fuel into the cylinder or fire the plug at the correct time.
The tolerance for getting those two items out of whack and still have the bike run are pretty slim.
And not sure how backing off the throttle and then getting back on it would correct that issue, as the OP has stated he has done many times.
But anything is possible I suppose. The CPS is a $$ fix so you want to be sure its that before buying one.
My next move would be to swap IAT sensors with your buddy and see if your bike clears up and his start stumbling.
Easy to do and cost nothing to try......as long as you can talk him to loaning you the sensor for a day.
I would also go over the entire wiring harness again, but I am an electrician, so that is my go to move.
BCS
LGB/FJB
BCS
LGB/FJB
