Unfortunately I cannot watch the video here on the ship.
Our IT department has streaming video locked down over our Sat link.
So any opinions I give are just WAGs at this point since I am flying totally blind.
The fact that you can cover the same ground with ambient temp in the 60s with no issue and then cover the same ground with ambient temp in the 80s and have trouble is odd though.
My thoughts instantly go to fuel tank venting issues, but we have already brought this up in previous post.
Maybe try this approach to that issue just for S&H, its easy enough and cost nothing to try.......If you have a spare key, put it in your fuel cap, take the bike out and when it starts having issue, reach down and unlock your fuel cap so it unseats from the tank while you are still riding and the issue is present. If the issue clears then we are on to something. If not it was a shot to test.
The only other thing I can think of that has not been covered so far is possibly the IAT Sensor (Intake Air Temperature Sensor)
I personally have never come across an issue with this sensor, but from the description of your problem it seems like a probable culprit.
There is a fault parameter for this sensor in the ECU which would be C-21. But I think you said you are not getting any fault indication at all, correct?
Below are print screen shots from the service manual for troubleshooting the IAT.
You will also notice in this screen shot it list P110 code as well as C-21 code. The P codes can only be seen using diagnostic software. The C codes are what will show in your odometer display when the diagnostic port is shorted.
I have in the past had P codes show up in my diagnostic software but not have a FI fault indication or C code present on the bike itself. (Can't say why, but I know it has happened at least once in the past to me)
If I remember correctly you were having this issue before getting your ECU flashed so its not likely that a wire was pulled loose when removing/installing the ECU causing the issue. But this has happened in the past and it can be a task to find the culprit conductor for sure.
It is worth a shot to double check that all the conductors going into the ECU connectors are firmly seated and a pin did not get pushed back into the connector when removing/installing the ECU.
Also visually inspect the pins in the connectors and on the ECU to make sure none were bent when removing/installing the ECU.
Also if you are start using a multi meter to probe the electrical on the bike, be aware of what you are doing. The multi meter can induce voltage onto or short components in the ECU that could cause more issues. Pay close attention when the manual says to check "continuity (ohms), a lot of times it saying to this with the ECU electrical connectors disconnected so you measure ohms of the sensor only and not measure ohms through the ECU.
(SDS that is mentioned in the service manual is Suzuki Diagnostic Software, which obviously you will not have. So you will not see the P codes or be able to utilize the functions of this software they mention in the manual)
Again, this is all just WAGs at this point but thought I would throw it out there as a next possible step to troubleshoot.
I think you said there is someone near you with a 2013, if you know him well enough, maybe he will swap IAT sensors with you to rule the senor out if you are getting proper readings as per the service manual.
You asked in PM if you could swap ECU's with him. Were you able to do that?
I doubt it is a ECU issue, but anything is possible. If it is, it would be the first time I have seen a ECU with intermittent issues.
The only ECU problem I have ever encountered is when I bricked one on my bike. I was flashing my ECU while it was in the bike and my laptop battery died right in the middle of writing to the ECU and I was not able to recover the ECU. Learned that lesson the hard way. (My bike is wired with a racing harness so I can access the ECU in real time while the bike is running)
When flashing customers ECU's, we are doing that on a bench with a hard wired power supply and desktop PC. Both of which are connected to a UPS, so there is no voltage interruption should the utility power drop. So no chance of that happening with a customers ECU.
The ECU is very robust but not indestructible, its an electronic device so it is capable of failing, though this is not common at all in my experience.
But I have had a few customers pull a wire loose when removing/installing the ECU in the past. This did cause issues but they were able to find the culprit conductor, seat it back in place and fix the issue.
Since your problem seems to only show it ugly head when ambient temps are higher, it does not seem that a loose connection at the ECU will be your issue. But anything is possible I suppose.
BCS
LGB/FJB
