Ethanol is hygroscopic, it absorbs and holds onto moisture like a sponge. So ethanol in fuel actual contributes to moisture issues.
Especially if it sits in the tank for long periods of time an absorbs enough moisture to become fully saturated.
At the start of each riding season I always get a few customers from the northern US & Canada contact me saying their bikes don't run well after they take them out of storage.
I have them dump the tank, install new fresh fuel and their problem magically goes away.
It's not a huge issue putting 5 gallons of fuel with 10% ethanol in your bike as long as you are riding the bike, using the fuel up and refilling the tank often. I run 93 octane pump gas with <10% ethanol in my bikes and that is the fuel we build up our ECU tunes with also.
But you never see fuel with ethanol being sold at marinas for boats. Boats often sit for long periods of time and the ethanol in the fuel causes all sorts of issues.
Ethanol is added to fuel to "improve" emission quality (so they say). But its really just a government feel good thing for the greenies. Sure the emission sniffer reading will show lower emissions coming from your exhaust, but you get less fuel efficiency by adding the ethanol. So you end up being able to travel less distance on a tank than you would burning pure gasoline.
You still end up using nearly the same amount of actual gasoline to cover the same distance.....so its not actually benefitting the environment in the way the government portrays it to push their socialist agenda..
Follow the money and then you see the real reason ethanol is being added to fuel.
I owned a air conditioning & refrigeration company for about 13 years and we had the same issue when the Montreal Protocol kicked in. Pure refrigerants started being phased out & blended refrigerants became more common place. Many of these new refrigerants required new synthetic oils be used in the compressors instead of mineral oil. These new oils were also hygroscopic and you had to really watch what you were doing when you opened a system up. If you left the system open to atmosphere for even short periods of time, the oil would become saturated with moisture and make your life miserable trying to get rid of it. Even after installing new filter dryers and pulling deep vacuum.
Lots of info on the internet about ethanol in fuel, the link below sums it up pretty well.
Try using DuckDuckGo instead of Google, Yahoo or Bing if you search for info, you will get a lot less propaganda and more factual info on the subject
Ethanol is a fact of life now, with 10% ethanol blends being commonplace for a number of years. See what you need to know about ethanol.
www.bellperformance.com
BCS
LGB/FJB
