Guest
·Down under kit installed an can't get it to bleed.... Any advise?
you have to remove you break caliper put something in it hold it upright and bleed then put back togetherDown under kit installed an can't get it to bleed.... Any advise?
:agree:you have to remove you break caliper put something in it hold it upright and bleed then put back together
That is odd, but glad you found the problem. I've never had a break line that had a blockage in it when new.it was the linepulled it off couldnt blow threw it even with a air compressor.. hope DL will stand behind there product and exchange it....
Wow, that is extremely rare. I would think that DLP will stand behind it.it was the linepulled it off couldnt blow threw it even with a air compressor.. hope DL will stand behind there product and exchange it....
Bro, you may have more problems than the line.... you may have a bad brake master coming apart or a bad hose breaking down or a bad caliper coming apart... in all my years, I've never seen a block brake lineThey sent a new one out today where very cool about it. Yea I have SB on all my toy never ran into this either. I even took a tip cleaner (for a torch) and stuck it in the little hole one side I got it in about 1 inch the other side 1/8 maybe less so it's right there but mightyvac or compressor would knock it loose whatever it is...:dontknow:
The line was brand new the old one worked fine, Id put the stock one back on but I'm running the down under kit.Bro, you may have more problems than the line.... you may have a bad brake master coming apart or a bad hose breaking down or a bad caliper coming apart... in all my years, I've never seen a block brake line
stranger things have happen however
